Beijer E1101 Need info!! can Anyone Help PLEASE
Mar 2005
54
Got a New machine with a Beijer E1101 can anyone help where can i get some info on it? I have been on www.e-terminals.com and downloaded installation manual.
The Reaason I,am looking for information is because, I was trying to Link into the machines PLC (FX1n) Via the HMI with no luck.
I'am currently only running GX ver7 and I know my E designer is only ver6 and will need to update.
So can anyone point me in the right dirrection PLEASE!!!
You will need to make sure that the HMI has passthrough mode set on the 232 port or it will not comunicate, however most people set this in the hmi project unless using dual protocol.
Passthrough? Why not transparent??
Btw. Software download to E is quite slow with RS-cable. I would use ethernet... It is also possible to use Tibbo software and connect to PLC via E-terminal ethernet-connection.
Hi Guys, I have the task of setting up communication between a S7-1214C with Version 3.0 Firmware, and a Beijer E1101 HMI. This needs to be done...
4,643
Hello! I am trying to get my setup to work but i have come across a problem! i cannot get the HMI to "write" i/o to the plc(like start buttons and...
3,356
Hi all, First post here, I hope I'm putting it in the right spot! I have an ancient Beijer E910T which went down today. Given the proximity to...
310
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
649
Has anyone put together a combination of the Beijer iX Developer software and a Rexroth L54 controller over ethernet? Can't seem to get the...
554
