S7 Mmc
stenter
Jan 2006
N.sembilan
Hi Guys,
I had problem to read my new 512Kb MMC using my PG. Error: An error occured writing to memory card.
I had tried with other PG and card and had a same error.
Please help.
well... i think that you should contact siemens to replace your card, if you know how to feed card with data (btw... what exactly you mean by PG ?)
or write more info about whole thing
there are many ways, how flash card can be damaged... including static electricity ...
i didn't tried that myself, but S7 MMC's are specifically formated to prevent users from usage of other's manufacturers... in case, it should be possible to destroy card using format in some other device (like those pc card readers)
... also where was minor bad-mmc-card shipment ... in history, all these were replaced for free by siemens... and it's very unprobable you own one of them... and you can check it on siemense website
Hi Marius..Thaks for the reply,
PG or Field PG is the laptop produce by Siemens. It had a MMC card reader built in the PG.
I'm not having problem with the 128KB card.
I had plug in the 512KB card directly to the CPU and load the programe to the card without any error.
Is it that 512Kb card cannot use with the card reader..??
Hi Does Siemens supply images for mmc's that have been accidently corrupted or formated?
90
my memory card has been formatted, I'm looking for the image file to use it. Thank you very much 6ES7953-8LF20-0AA0
633
Is there a way in the S7-1500 to read the contents of a directory on the Memory Card? I'm using the web browser to 'upload' .csv files to the...
1,555
we are still running quantum plcs and proworx but because it wont run on any new computers we are starting to upgrade our systems to unity. the...
774
Hi, All I have been tasked with uploading configs from two running Siemens PLCs. One from an ET200 and one from a S7-300. I have no real previous...
1,400
