I am developing a modification for our production lines for OEE, when the line stops i move the current Date/Time to my DB and when the line restarts i move the current Date/Time to my DB also, i then calculate the downtime from the two DT's, this is all working fine.
What i cant get my head round is this part, when the line is back up and running, an OP177 panel will request a reason why the downtime occured, the operator will have several fault selections on screen. My problem is, what if another fault occurs before the operator has gave a reason for the first fault, how do i go about queing the next fault??
i can post my source code if this helps?
thanks
LH
thanks
LH
