S7 programming explanation
arocon
Oct 2006
Dubai
171
I attached one Function Block. In Function Block network 2
is Integrator FB 8 from siemens block. Could any one explain me how EN (DB310.DBX32.2) works.As i understand when DB310.DBX32.2 is 1 then this integrator work, But DB310.DBX32.2 should immediate become 0 as ENO of Integrator connector with reset of DB310.DBX32.2 . Now it is 0 (En=0) , so Integrator is disable, then how integrator is working.
Anybody please explain it will be great help.
From the manual -
Meaning of EN/ENO
Enable input (EN) and enable output (ENO) of the LAD box
The LAD box enable input (EN) and enable output (ENO) parameters function according to the following principles:
  • If EN is not enabled (i.e., the signal is set to "0"), then the box will not execute its function, and ENO is not enabled (i.e., the signal is also "0").
  • If EN is enabled (i.e., the signal is set to "1"), then the appropriate box executes its function, and then ENO is also enabled (i.e., the signal is also "1").
Therefore ENO = 1 only when the block has executed its function.
Look to see where the bit is set high - it has probably been done to execute the block only on certain conditions such as a time delay??
Try searching in the project,maybe DB310.DBX32.2 is set somewhere else.
Then right click on DB310.DBX32.2 goto location..
A question? why you have created a fb,you use addresses of db internal of fb?
Fb have input and output also..
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
206
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
134
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
939
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
93
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
490
