S7 Safety - QBAD_I_xx Not Turning Off
hein123
Aug 2010
Uitenhage
93
I have a strange problem.
We have 6 cart, all setup, wired exactly the same.
On two of those the QBAD_I_xx does not turn off.
The safety card is a 4/8 F-DI DC24V and it is connected to a HMI Mobile Panel --> 6AV2125-2GB23-0AX0, the enable and estop button.
We swopped out HMI's, cables and cards with no luck.
The device works as it should, estop and enable button working as it suppose to.
Any advice would help a lot
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
25
766
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
111
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
241
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
