S7 word copy pointer problem
spaderkung
Aug 2007
South Sweden
389
Hi!
I use the following code (from FC) to copy words between DBs given an word offset address and nbr of words to copy. But I found out it fails for byte adresses 4096 and above and I don't see why.
L #i_SourceDB
T #iDB
OPN DB [#iDB]
L #i_DestDB
T #iDB
OPN DI [#iDB]
LAR1 P#DBX 0.0
L #i_SourceElementsOffset
SLD 4
+AR1
LAR2 P#DIX 0.0
L #i_DestElementsOffset
SLD 4
+AR2
L #i_NbrOfElements
LA: T #iLoopCount
L W [AR1,P#0.0]
T W [AR2,P#0.0]
+AR1 P#2.0
+AR2 P#2.0
L #iLoopCount
LOOP LA
SET
SAVE
+AR1: The integer (16 bit) to be added to the contents of AR1 is specified by the value in ACCU 1-L. Values from -32768 to +32767 are permissible.
Code:
LAR1  P#DBX 0.0
      SLD   4
      +AR1
      LAR2  P#DIX 0.0
      SLD   4
      +AR2
Could it be that you try to add a number larger than an integer with ar1
try this
Code:
l P#DBX 0.0
SLD   4
+D
LAR1
L  P#DIX 0.0
SLD   4
+D
LAR2
This feels like a simple, elementary question, but I am a Siemens novice and know there are experts here. My S7-1500 project (TIA Portal v17) has...
2,714
Hi, I'm still at the beginning of my journey with TIA, and am doing something for which I'm sure there must be a better way than writing each bit...
2,741
Hi all, Straight up question: I'm using TIA Portal and an S7-1200, and wanting to do a straight bitwise copy of all the data in a Word to put it...
20,091
Good evening Hope I can get a little help with this one :) When I scroll true my DB and find a certain value, I would like to copy the actual...
2,328
Hi, I'm starting with the ladder logic programming and I want to enssure if the following bitwise operation is correct or not. I want to...
1,708
