S7300
Kidblue
May 2003
Worcester
698
Could somebody please point me in the right direction regarding a few queries i have with my first S7300 project.
Hardware comprises;
2 x 315-2DP CPU's (With software redundancy loaded)
2 x IM153-2 Modules
2 x CP341 Modules (One as Modbus Master, One as Slave)
3 x 8AI Cards
1 x 2AO Card
1 x 32DI
1 x 32DO
After wrestling with the redundancy issues, i now have that working fine. The Modbus SLAVE side of things was pretty straight forward, this was connected to a Honeywell DCS system and is communicating fine. The problem i have is with the Modbus MASTER side of things. The problem isn't really with the Modbus - i have it talking nicely to two Atlas Copco compressors acting as slaves quite well, it's with S7300 and how to best organise my code.
I have used the sample code already written for the Modbus master driver (with a few little tweaks here and there). What i want to now do is set up multiple transmissions to the slave devices. It's now knowing which blocks i can use again, and which ones i have to generate as unique blocks/addresses? I think FB7/FB8 are the actual comms blocks that initiate CP - CPU and vice versa, and DB50/DB70 are the respective assigned instance blocks. What i'm not sure of is the other FB + DB's that are used. There are 4 other DB's used that contain the various parameters for transmission. I need to execute Modbus codes FC01/03/06 on both slave units. I have figured out the principle for this, but not quite how to implement it yet!? (i was just going to increment a register on the 'Done' bit of each successful transmission, and then initiate the next and so on.....)
The samples are written in STL and so it doesn't jump out at me what is probably obvious to experienced S7 users. I can follow what is happening, but not conversant enough to know where i can re-use existing addresses.
I still have two PID loops to set up, and the screens for the MP370 15", but i seem to have got bogged down over this FB/DB stuff.
Any input appreciated.
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
130
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
187
Hi guys, I'm having problems converting WinAC (WinLC RTF F application) to S7 300 project based on CPU 319F-3PN or S7 400/416F-3PN. The problem is...
623
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,018
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,080
