Safe Heater Control Best Practice (preventing runaway)
When I have dealt with heater controllers that use SSRs, I have used a shunt trip breaker upstream of the SSR wired to a fault contact on the controller. If there is a PLC in the mix, I might also wire a PLC output to trip the breaker in case I detect anomalous temp signals.
The shunt trip breaker is more compact than a contactor in many cases and you need circuit protection anyway.
I like this idea, this would save panel space as well. Thank you for the input.
Can somebody share the AutroSafe configuration Tool C4.11.4 Thank you
114
I have a GuardLogix PLC with safety inputs of HMI, Estops, Light Curtains, and Gates. Is it considered safe for the safety program to monitor the...
785
We have an existing VSD where a three phase circuit breaker feeds the drive, and two phases also tee off to a contactor, which is energised to...
1,490
Hi, I'm trying to understand a couple of things with a feedback signals that are used in a SRP/CS that I'm working with. Quick disclaimer: I'm...
536
