safeload device help
dinetech
Jan 2011
Oakland
I'm looking for a safeload device other than using ct with analog card on a plc. current range is 10 amps. I use to remember a AB current relay w/time delay which is not longer sold? I'm not comfortable using a PLC monitoring the equipment. Your help is greatly appreciated.
In the terminology I'm familiar with, a "safe load" device has to do with cranes. But it doesn't sound like you're referring to one of those.
Are you talking about a conventional 3-phase overload relay, or a single-phase monitoring relay of some type ?
Describe more about the application, especially about the safety aspects.
the current relay in on one phase of the 3 phase after the starter. safety relay that senses a jump in current it shuts off the equipment. this equipment is a Industrial conventional Oven (tray). so its important before it tries to destroy itself?
The problem I have in the plant is no one understands the PLC. a simple device could be install and reset. Second the HMI don't display the current instinctively. this display should have a analog meter so you see the jam up.
A monitoring relay like this could be used http://www.phoenixcontact.com/onlin...14-10-01/ccbba64a-0174-4263-8175-b4d204099b69
or something that provides an analogue out. I've used many of these over the years.
http://www.synctek.com.au/LMR10a.html
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
111
Hi, First time poster, long time reader. I've got a mass flow controller device for controlling the flow of gas. It has a flowmeter and an...
276
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
586
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
147
