Safety evaluations/SISTEMA library for FANUC
becs
Mar 2012
Ontario
20
I'm doing a safety evaluation for a robotic system using a FANUC robot with DCS. To do the evaluation I am using the Siemens online safety evaluation tool.
I have imported the libraries for Rockwell, and Schmersal, but can't find a library for fanuc robots. The best I have found is a FANUC safety manual which tells me the Cat, PL and SIL for a few functions.
Does anyone know if FANUC makes their PFHd information available anywhere?
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
25
755
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
111
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
241
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
