Safety PLC
Johnny Rotten
Dec 2004
Ontario, Canada
194
Am going to be upgrading some of our equipment using a safety PLC, and sensors to Cat 3. I'm close to choosing the plc and what have people used with success for non contact sensors?
Thanks, John
Are you referring to single beam sensors?
If so, I've used Sick, Leuze, and Schmersal with success.
I tend to gravitate to Leuze as the pricing is good and almost always in stock.
The SafePLC is typically dictated by the platform you're using.
Sensors are tricky and I've never been fully satisfied with anything I used. Most safe inputs send out a stream of pulses and monitor for that stream coming back. This lets them check for circuit breaks, shorts, and wiring mistakes for E-Stops. I haven't found a no contact sensor that will pass these pulses through. There are some sensors made for particular safety systems that support pulses for their own system only, but they typically lack some key anti-tamper feature that still gets them stuck in Cat 3.
I did see one directional magnet based door switch that acted as a relay so it would pass the pulses, but I never got to see what brand it was or a part number. So, they exist, but are hard to find.
I'm referring to magnetic and radio frequency non-contact sensors.
I use the the Schmersal RFID based solenoid interlock and non-solenoid interlocks quite frequently. (RSS 36, AZM300, etc..)
I've found them more reliable than the coded magnet types (no wear, good range, easily daisy-chainable, etc..)
They are more expensive but I can also up-sell them. They are also category 4 / SIL 3.
Why go radio frequency vs coded magnetic sensors?
In my experience, coded magnet sensors can be flaky and give you a lot more false trips. The magnets have to be perfectly aligned and as guards and things wear out, you have machine vibration stopping the machine at random times, much to the annoyance of production.
RFID is a lot more forgiving with vibration, and you can typically move the actuator much further away from the sensor (but not so far as to actually endanger anyone) than you can with a coded magnet.
I've ready through the the previous posts, and we've worked with safety design for a long time. In the past, we worked with Pilz directly, and...
581
Hello, I have been programming with Logix for over 2 years now, my current job just put me on a job where we had to change some of our original...
949
So I'm still a little new to LC muting, and currently do not have a test bench. THE SITUATION My LC function is set to manual reset. I mute the...
955
Hi guys, This my first time posting hope I get help in my issue.. I have Allen bradley control logix safety PLC (1756-L61S) connected with...
2,313
Good evening, I'm primarily a Siemens user, but I have an incoming project where I need to use Allen Bradley everything. So far I know that the...
2,646
