Safety with an S5 135 PLC, output card transistor question
timbo_uk
Nov 2005
Bradford, UK
336
I am looking into a potential safety implication on a 13 year old machine on our site. Before I kick off with the manufacturer I wanted to get a general opinion.
Am I correct in assuming that a transistor(24vdc) output card on an S5-135 system CAN go short and fix the output to on, without indicating and/or being detected as a fault by the PLC?
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
24
608
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
110
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
240
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
116
