SafeZone Safety Laser Help
Ryan_Flowers
Feb 2019
Las Vegas
57
Hello again!
I have a new piece of equipment and there is a SafeZone Safety laser attached to both sides of the traversal unit (442L-SFZNMN A). One side operates just fine but running it to the other side is currently a no go. The laser on this side is sensing objects in the field no matter what orientation I put it in or if I clean the protective cover with alcohol. It doesn't show any errors or faults, just that it senses objects in two of it's fields, when the previous day it did not and functioned normally. It looks like someone may have hit the device, but no telling when or how, and the bracket is only slightly bent. No other damage to the cover or housing is detected.
Manual Here
I tried to see if I can use SCD software for it, but after I downloaded "SafeZone Safety Laser Scanners" v3.02.05 from RA Compatability and Downloads, it won't allow me to continue unless I give it a serial number. Of which I do not possess.
SCD User Manual Here
Can someone point me in the direction of some help with this? I am definitely not familiar with this type of device.
Thanks in advance.
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
24
694
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
110
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
241
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
