Sato Printer and SLC 504
Jan 2015
US
I have a Sato M840Pro-2 Printer that is linked to a SLC 5/04 processer through a Prosoft communication card. The SLC sends information in ASCII to the sato to print on a label. There is a photo eye in the printer that detects if a label has been printed, but not removed. I am looking for a way to communicate this information back to the SLC. Would this be even possible? If so, what would the code look like. I am not familiar with these printers and would appreciate any help. If more details are needed, feed free to ask.
Thank you for the manual. I think I should post an update on where I am at in this problem.
I have found the manual and found the respective codes in the slc. I have found that the smc sends an enq command using alternative symbols (@) at set intervals. I have also found that between these enqs it sends the following ascii line:
{^A^*^Z}
I believe this is to clear the buffer.
In the manual, under the bi com section, it mentions a SG command, which would return the signal levels of the sensor. I believe this is what I want. However I cannot structure the line correctly to get this return.
Does anyone have an idea on the structure that this should be in?
I have a new L306 CompactLogix running V33 with a 5069-Serial module in order to send data through RS-232 to a Sato S84EX printer. I'm unable to...
1,330
Hi, I need some help on how to write the command to print a string of ASCII code to a sato printer The sato printer model is CL4NX (2 unit)...
4,115
Does anyone have an Omron example sending ASCII code to a Sato printer. I will be using RS232 communication. The PLC part number is CQM-H1-CPUP1...
3,613
Anyone know SATO printers? I have a PLC program that outputs strings through a serial port to a SATO printer. (See "Printer Routine" and...
5,541
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
59
