save the status
May 2009
egypt
43
Dear all,
I want to know if PLC siemens can save the status of the IO in its memory so if I need this status I will download it to the PC on excel sheet
Hi there,
You can do this by creating the DB and then storing the status in this DB, at given instant of time. Dont know how to export it into Excel
well
well
Manmeet gave u a solution. Just write into DB's, DB's are retentive. Write it every cycle in case of 'production active' for example.
Even when the machine is getting a power failure/lost, after restarting the CPU, the 'production active' is low, so the last status from when the production was busy can be readout, to see what caused the failure for example.
I don't really know what you need, but I guess it's something like that ? Or do you really need it in an excell ?
Dear Daniel
thank you for your help but if the communication between plc and opc has failuer how can I save the status of IOs in the PLC
Kindly, we are using Siemens Pcs7 v6 cfc blocks. But, sometimes we are getting fast changing signals on the inputs of the Interlok block FB75 in...
1,138
Hi; First of all, I am sorry that my post is not relevant with this forum. I have recently purchased Samsung cell phone. I have alreay saved...
77
Hello! I have a datablock in a PLC witch contains about 700 variables. I must save this data once a day on a Windows PC in a XML or CSV file. Eg...
491
Hello Folks! I have an issue and its very often but in this case i applied all the tricks and tips that i always do in similiar issues but in this...
778
I'm a bit stuck again... See the redacted picture. At the moment, pressing F7 saves the "live" laser measurement into the boxes indicated by the...
1,081
