Saving FTV Projects
PLC Pie Guy
Jun 2013
Halifax
1,144
Hey all.
I was looking at past threads for something about this but no luck. I am curious about saving FTV projects.
I am wondering if I can save a copy of the project to another location for backups sake. Yes I can open FTV and open a project from its default location there but at this point I don't have it saved anywhere else.
My "SAVE AS" is grayed out!
Any advice?
Thanks in advance.
Assuming that FTV is Factory Talk View (and I'm running FTV Studio ME) you pretty much need to use the Application Manager to backup a project into one file in the location of your choice. Projects really should not be manually moved around without the backup process.
The 'Save' and 'Save As' in FTV is for each thing that you're editing - displays for sure and maybe some other items as well.
Hey, no problem.
BTW, the inverse process is within Application Manager and is called 'Restore Application' - sucks the files out of the backup and places them in a folder somewhere in the Rockwell software folders.
edit: finally found the project folder location: C:\Users\Public\Documents\RSView Enterprise\ME\HMI projects
Hello guys i have a big problem with the datalog in FTV-SE (v10). How do you guys manage the daylight saving time (summer time) change? For the...
7,293
Hi everyone, i have an issue with saving a changed value in an AOI, I am using L84E, Everytime i try to save my work to SD card, the program lost...
101
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
102
Hello, i have a problem, i was trying to fix a trend that wasn't registering the tags, i got that fix by setting the path, but now i can get it to...
848
I'm struggling with this...Times and Dates are always a mental-block for me. See picture. When I press SAVE, I want to take the current...
1,709
