Saving Graphs in Factorytalk view ME
tierneae
May 2014
MI
Hello,
I am trying to create a system that will allow me to save a graph after a test has been run and then to be able to search those tests by name and view the data. A USB will be plugged in and can be used as resource. Please help. I have no clue what I am doing.
Sorry that was a very short answer
The trending displays data on the HMI
You can setup the same data to be saved (logged) to a file on either a USB stick or a CF card.
This can be stored as a CSV format file and read into Excel later and then graphed
If you want to see this over a longer period and look a history.
Talk to Rockwell about Historian.
Thank you so much, is there some place where I could get a step by step tutorial for this? My skill level is comparable to a college freshman (because I am a college freshman), and I would feel better if there were a few more details filled in.
Are you using a PanelView Plus terminal, or running FactoryTalk View ME on a Windows XP or Windows 7 computer ?
The Trend object in FactoryTalk View ME does not log data into an exportable format; it's a binary-encoded, proprietary log file.
If you set up a "Data Log Model" then the data is logged into a log file on disk, and can be manually exported and converted into a text file. If you don't set up a "Data Log Model", then the data is cleared as soon as the Display that hosts the Trend object is closed.
There is a separate method for logging data in FactoryTalk View ME, called the DataStore Plus ActiveX control. That directly creates a log file in CSV format, and can be started and stopped programmatically so that you can go look for the data files later. The ActiveX generally puts the starting timestamp on the data file name, but does not support prompting for a filename.
These two methods for displaying data and recording data are separate. Inside FactoryTalk View ME, you won't be able to go select a DataStore log file and show it as a Trend, nor will you be able to individually save particular spans of time from a Trend as a separate log file.
Is FactoryTalk View ME your only choice for this project ? There are competitive products with much more powerful datalogging features.
I am trying to save my graphs into a file. I would like to have them start on a specific time and end on a specific time. I would like to save...
3,815
Hi everyone, i have an issue with saving a changed value in an AOI, I am using L84E, Everytime i try to save my work to SD card, the program lost...
95
Hi all, I have installed a SICK AFM60A-S4IB018x12 encoder to Allen-Bradley CompactLogix PLC and configured its parameters via AOI provided by...
97
Hello, i have a problem, i was trying to fix a trend that wasn't registering the tags, i got that fix by setting the path, but now i can get it to...
833
I'm struggling with this...Times and Dates are always a mental-block for me. See picture. When I press SAVE, I want to take the current...
1,691
