saving tag database
chue.lee
Sep 2008
California
Is there a way to save the tag database in rslogix 500? I can see all the tags in the "excel address/symbol editor". I need to import it to factorytalk view studio because when I tried to import the tags in factorytalk, it doesn't grab all the tags. I'm missing bunch of timer tags and interger tags and others. It only gives me partial of it. I had to use to different saves of the same program to grab more tags. Or am I doing something wrong? Any help would be appreciated. Thanks
And another problem I just came across on, on the other computer here with me, in the "tag import and export wizard" in factorytalk view studio, it gives the options of factorytalk files only and this computer gives off rsview files only. Why the difference?
We had a problem that may or not be applicable.It seems that only a limited number of tags may be imported at once. The missing tags may be in the upper range alphabetically. I hope this helps.
I'm struggling with this...Times and Dates are always a mental-block for me. See picture. When I press SAVE, I want to take the current...
1,697
Hello, During runtime I change values of some internal tags (i.e. F_CV of DO tags). And I want them to be saved when I switch runtime off, and...
5,463
Hi everyone, I have to modify a program that has been running in the field for several weeks now. I would like to be able to save the tag data...
6,539
  • Poll
Can anyone help. I am a novice user of WinCC Flex. I have a project that i just want to log 60 Tag values into a CSV file once an hour. I...
5,779
Hi everyone, i have an issue with saving a changed value in an AOI, I am using L84E, Everytime i try to save my work to SD card, the program lost...
97
