Scada for S7-200 smart
Faazil
Aug 2018
Colombo
Hi dear all,
I have a S7 200 smart plc. I am using Micro win smart to program the PLC. I had no luck in designing the Scada system I tried out wincc 2008 flexible but connectivity is the main issue. I am using the Enternet cable and I prefer using it. Please help me out. I have to finish this project soon
There is WinCC flexible SMART V3.....
I am not sure but as I remember that if Scada works for S7-1200 it will work also for s7 200 Smart....
Switching to Modbus RTU protocol will help you with connectivity.
https://support.industry.siemens.com/tf/WW/en/posts/s7-200-smart-with-v20-modbus/118107?page=0&pageSize=10
https://w3.siemens.co.in/automation/in/en/automation-systems/industrial-automation/s7-200-smart-plc/pages/faq0120-5762.aspx
https://support.industry.siemens.com/tf/WW/en/posts/communication-b-w-wincc-flexible-pc-runtime-and-modbus-meter/67097?page=0&pageSize=10
The above links may help you out with connection between the wincc 2008 and S7 200 smart plc via Modbus RTU.
You may also want to check out AdvancedHMI for the communication. This would also help you test the Modbus communication.
https://sourceforge.net/projects/advancedhmi/
Regards,
And I used some time ago on PC scada named Promotic.....it is free up to 30 variables and it works using ethernet connection (IP adress)...
it works without problem with Smart PLC....
Hello PLC Friends, I'm starting my final year project with a given rig and I'm thinking about incorporating a remote access feature where I can...
378
How to check the communication between the Micrologix1200 to Citect SCADA. I use PLX51-DF1-ENI router to communicate in scada. I tried to use...
1,354
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via...
1,463
Hello all. I am building a machine that tests a product by extending it and retracting it. During the travel we measure force. The process is...
1,618
Hello! I am beginner in PLC world, also in SIEMENS PLCs. I managed communication over private network. Now I have a problem that I get same...
2,551
