Scadapack
sayahan2003
Jun 2006
Calgary
185
Hi My Friend,
I need to read a register (for instance, register 42000) from one Scadapack and put it into a register (for instance, register 43000) of another Scadapack. Would you please let me know how to do this? Both Scadapack communicate over Ethernet.
Thank you
4.6.2 Modbus/TCP Client Communications - Must enable the service
4.6.3 Modbus/TCP Server Communications - Must enable the service
Please refer to the above sections of the manual. You do not have to have function blocks programmed in the server but you do need to ensure that the service has been enabled.
You are correct, all of the communications are initiated by the client.
Regards,
Regards,
Awesome! Much appreciated Garry.
Hi People, I have a ScadaPack 330E that has been sitting on a shelf for a few years (previously working), and have recently re-installed...
1,803
I've got 16-bit data at address 40200 on a Schneider Scapack 350. I can grab the data over Modbus TCP using Kepware at IP 172.16.1.100. When I...
2,499
Hello, I’m still a novice when it comes to plcs, and I’m currently facing a problem I need help on. I’m on site at the moment, and connected to...
1,527
I am programming a SCADAPack 350 with Telepace Studio. I want to know if the logic in running the first scan and if the program is running...
1,258
Hi! I've got a customer that has several SCADApacks at remote sites and I need to make changes in their cellular network system. I have the .pia...
1,893
