ScadaPACK32 - Obtaining a MAC address
Cyanogen281
Oct 2013
Houston
I have a question regarding the ScadaPACK32 being identified by a MAC address.
I present to you a fictitious scenario that I have been eager to know the answer to.
A technician is out in a remote area with only a laptop with all of the necessary software to connect with the PLC (Telepace/Telepace Studio), and an Ethernet cable. He does not have a serial cable or know the IP address of the PLC.
Is there a way to read the MAC address from said ScadaPACK32 and possibly read or write an IP address to it? Perhaps by scripting or some third-party application.
Allen-bradley, Siemens, and a few other brands include this feature in their product I was just unsure if Telepace or Telepace Studio could perform such a feat.
Thanks for the help,
Why not connect thru its serial port? Once you read from the controller you can then take a look at the Ethernet's address.
I meant if I didn't have a serial cable... If I ONLY had an ethernet cable and didn't know the ip address of the PLC...
Regardless of whether or not the program is retained or deleted, is there a way to obtain an ip or MAC address from the PLC?
Hey everyone so I am more IT then Automation...so this question is probably something simple. All I am needing to do is make a ScadaPack32...
4,805
Hi everyone, I have a question: In Scadapack32, if I want to read Calculated flow in Telepace from Realflo meter run. How can I do it? Thanks a lot.
1,861
I want to meter run's data in Scadapack32 to Wireless Data Transceiver 5908. I use Telepace and RealFlo software in Scadapack32. Does anyone can...
1,787
I am working with a ScadaPack32 PLC, with Telepace LL, with a Panel view Plus. Is there any way to get the tags of the PLC to the RS View Studio...
2,033
Hi all I've got the following with IO: 0 CPU363 1 CMM321 2 ... Over ethernet I'm connected to a PC running Citect and a ScadaPack32. It's a...
4,481
