data access from Telepace to RealFlo in scadapack32
wilsonzhu
Jan 2008
vancouver
278
Hi everyone, I have a question: In Scadapack32, if I want to read Calculated flow in Telepace from Realflo meter run. How can I do it? Thanks a lot.
Their are registers set aside for each meter run. For ex. Run No.1
data can be found in Registers 47500 to 48489. See RealFlo manual under TeleBUS protocol. (see PDF below for run 1 data location.
To ansewer your question the flow rate can be found in register 47528
Hello, all, total noob here hoping for a little guidance. I bought a new piece of printing equipment that has a Mitsubishi PLC and this Data...
189
Data Acees Error for Alias A_THMC_REV_POL, controller PLC-1
154
Hello all, PLC-programming noob here. I have multiple clients accessing some data on my Siemens S7 1211C PLC; some OPC clients and some direct...
30
8,365
Hi everyone, I'm working with a company that is developing software that will be used to access and process sensor data from different process...
1,905
So the micrologix 1100 has a built in web server. I have been following the user manual 1763-UM002. After I enter in my controller's IP address...
1,205
