SCALANCE S612 as NAT/router
Nov 2012
Pretoria
Hi Everyone,
I have got an issue with SCALANCE S612 from Siemens and I hope you will able to help. I want to set up a simple connection between two PCs through a SCALANCE S612 as a test for future use.
The SCALANCE S612 v2.2 is set as a router/NAT. On the external port of the module I have connected one PC with IP address 192.168.2.100 subnet mask 255.255.255.0 and Default gate way 192.168.2.1 (which is the IP address of the external port of the SCALANCE S612). On the internal port of the module is connected another PC with IP address 192.168.0.25 subnet mask 255.255.255.0 and Default gate way 192.168.0.1 (which is the IP address of the internal port of the SCALANCE module).
The routing mode of the module is active as well as the NAT option where I have set the external IP address as: 192.168.2.100, the internal IP address as 192.168.0.25 and the direction: External->Internal.
My IP rule in the firewall is as follow:
Allow External->Internal SourceIP: 192.168.2.100 DestinationIP: 192.168.0.25
I have been trying for a couple of times now but I am not able to ping the internal device (192.168.0.25) from the external PC (192.168.2.100). Though I have configured my router to allow communication from external to internal network I am not able to ping the internal network from the external network?
Surprisingly, in this configuration (external to internal) I can ping the external PC from the internal PC without even configuring it. How is it possible??
Is there anything I am missing in the configuration?
Your help will be really appreciated.
Kind Regards,
Sonia
Does anyone have any examples or experience in time syncronizing their S7-300 PLC and MP3xx HMI with an NTP time server? My set-up External...
3,775
We are having an issue with some servers, with "Teamed NICs" is we plug one cable leg of the team into one switch and the other to another...
65
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
201
Can the XM408 Scalance Switch ( 6GK5408-4GP00-2AM2) be integrated into a Step 7 ( v5.6) project via Profinet so that we can read the switch...
1,281
Hi Everyone, I'm currently working on some OT network upgrades for my company across two sites. Painfully, the two sites have gone in different...
1,309
