Hi everyone I have the following:
1.- PLC S7200
2.- HMI tp177b pn/dp 6"cstn
3.- Temp. transmitter IFM TP9237
2.- HMI tp177b pn/dp 6"cstn(image)
https://www.lagerwerk.com/elektrik-...ch-panel-tp177b-dp-6-mstn-6av6-642-0bc01-1ax1
3.-Temperature transmitter(image)
http://www.ifm.com/products/mx/ds/TP9237.htm
http://www.ifm.com/products/mx/ds/TM4311.htm
I want to create the scale so I can get the temperature value(° Celcius) on the PLC and then read the value from the HMI(tp177b pn/dp 6"cstn) and display it.
So I'm using a library called "scale.mwl"
I already have connected the temp. transmitter correctly, before doing it I cheked the voltage outup value(from the transmitter) with a multimeter and a lighter and could see the voltage variation(0-10V) as the temperature went up/down.
Now, I have no idea what variable or where I should be reading the engineering value from("32000-6400" or "32000-0"?)
I don't know wheter its going to be adressed to AIW2 or VD100.
I also have to select between three block types for scaling: S_ITR, S_RTR or S_RTI, and don't know what's the right option.
Blocks images:
http://i.imgur.com/ta9DVQX.png
The temperature range that I'm going to be using is between 10 to 60°Celcius more or less...(50°F to 140°F), I need the value in celcius
Could you be so kind giving me some orientation please?
Thanks in advance.
Best regards
1.- PLC S7200
Blocks images:
Thanks in advance.
Best regards
