Schematic
If you already use one or more: the one you know best.
If you don't use one already: none. They all have their advantages and disadvantages.
The key factors you didn't mention: what can (and are you willing to) spend and what do you want to do with it?
BTW this goes for all "what's the best" questions around here.
To day i don't use anything. I have some jobs on hold. The price has not so important as long as the program has high quality and easy to use. I think i want to try Eplan. do you have some experience with it?
I have been using Eplan for the last 8 years.
It is an expensive product, depending on what your requirements are as regards users/ licences, can make your eyes water.
Expect a steep learning curve also, it is not simple with a myriad of rules and regulations,
but if you put the time into it you produce top quality schematics.
I only have a single licence for the P8 compact version which I bought in 2008 at that time it cost around E1400.00.
I have not upgraded it to the most up to date version.
I am a lone operator and I only do around 5 or 6 projects a year where I need to produce schematics,
and with the database of templates I have accumulated I can produce schematics very quickly.
I love eplan. It takes some effort to set up (you might want to hire an expert to assist you, I can recommend someone in Norway), but if you make enough drawings it is totally worth it.
in Norway they are sells the software with 2 day course. i have a big automation job to do in the future. so i thing eplan is a good choice
Hello, fairly new to plcs I’m tasked with installing a PE to a micrologix1200, in the attached picture I/14 is the PE I’m installing it’s going to...
971
This is my first IO-Link project. I am having trouble figuring out how to draw this in ACAD-E. How to show the system as well as the wiring to...
1,778
There are so many different ways to tackle the first sheet of the schematics. I've seen some people with a cover sheet, followed by several...
2,633
Which Style to you expect to see on a drawing? Which style to you prefer? Keep in mind this being used on very large projects Style 1 Style 2
21
6,789
Hello, A couple of questions regarding NEMA schematics and terminal block labeling. 1) I am familiar with the DIN designations for components...
3,145
