Schneider Electric M241
bill4261
Jan 2005
mid-west
99
I have a machine that has M241 PLC. I need to add a couple of outputs to the program, and I don't have the original code. Am I screwed or can I buy the software and upload it? If so, does anyone have a ballpark cost on this software.
Thanks,
M241 is codesys programmamble PLC.
It can have source code file downloaded automatically to PLC ,but as it is by default not selected and if it isn't downloaded seperatly after code download it is impossible without offline project on laptop.
https://help.codesys.com/api-content/2/codesys/3.5.14.0/en/_cds_loading_sourcecode_to_from_plc/
Your best bet is install M241 program with trial mode? (Thinking that it has trial mode) and try upload source file from PLC. Also it it useful to install same version of which it is downloaded (Somachine V4.x or newer machine expert)
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
239
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
120
Hello, Does anyone know why this AMO 0410 or AMO0410 module flashing all 4 channels with green LED and the IO LED on the display is solid red ...
490
I am using a M221 PLC (TM221CE24R) which provides me 1 Rs485 port, which I am already using to communicate with a sensor (Rs485/Modbus). My...
749
Hello, I am trying to detect when the PLC changes from STOP to START mode. This can be considered an edge case scenario, but I would to analyze...
1,569
