I am trying to read Schneider power meter PM2120 data using M221 plc.Power meter Pm2120 is connected to serial port of modbus/tcp gateway EKI1222.The modbus gateway is connected to the M221 PLC ethenet port.I tested using a modbus simulator and I am getting readings of the power meter in the modbus simulator via the modbus gateway. But I am not getting the readings tru PLC.
The IP address of PLC is 192.168.0.1,gateway is 192.168.0.10.Slave ID of power meter is 1.Please check if the plc configuration is correct.attached plc configuration
