Schneider M580 Peer to Peer Communications
DrWarm
Apr 2009
Australia
Hi everyone,
Can't seem to find the answer to this on this forum or google. What is the recommended method to exchange data between M580 PLCs peer to peer?
Previously with M340 I have used NOE/NOC cards and I/O scanning to set up memory areas to do messaging. Is this still possible with M580?
I'm a bit confused, as now they mention RIO and DIO scanning possibilities of the PLCs. I also see you can use Ethernet/IP, but this has a limitation of 1 PLC cannot talk to more than 3 other PLCs (my understanding anyway).
In our current architecture we will have 1 master PLC talking to 12 or more slave RTUs collecting and sending data.
The M580 definitely still supports the IO scanning style you'd be used to with the M340 NOCs. DIO, or Distributed IO, is exactly that.
Instead of using rack extension modules you now use RIO scanner, and the link is over ethernet. However its deterministic, as opposed to RIO which isn't. Not a major deal for collecting data from an RTU.
Absolutely no reason you couldn't IOScan 12 RTUs using an M580 and a NOC.
Thanks for the replies.
@BobB
Sorry I'm not familiar with these modules, I'll look into it. If the engineering is easier might be worth it depending on price.
@Saffa
Will I still need a NOC card in the M580 racks? As all the M580 CPU models have DIO built into both ports (models ending in 40 have RIO as well). Hoping to get away without purchasing additional hardware.
Schneider - expensive mate. Using them on a job at the moment - apart from the software quirks not too bad to set up. Software is a pain for mine - oh well.
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
150
Looking for some advice on a project. The controller is a BMEP584040. There is a RIO ring with several drops with Quantum I/O. On this ring...
1,023
Hi, Does anyone know if programming a Modicon M580 is basically the same format as an M340? Also do they use the same software package? Thanks...
1,783
Hi Folks, We have this M580's configured as hotstandby and is curious if it is possible to monitor the modules on the remote racks. Unity pro...
1,593
Hello, Wondering if anyone else out there has experienced issue with Scan Time on H58-6040 m580 processor. These controllers have a periodic...
3,045
