Schneider Modicon M340 CanOpen error
david_n
Jun 2019
Krakow
I'm configuring the M340 controller with ATV320 inverters via Canopen. Everything was fine until today, when after starting the electrical cabinet, the CPU cannot communicate with the inverters. Nothing has been changed since yesterday not even touched.
Below are errors from the CPU and Canopen:
CPU:
https://pasteboard.co/6PwOb5TpPxKP.jpg
Canopen:
https://pasteboard.co/SZOAaTLiA6Lf.jpg
CPU is in RUN so I/O modules run normally.
Please help me solve the problem,
greetings
With the ATV320 this is normal behaviour after a power cycle.
In the slaves you need to specify what the master does to the slave (atv320) config at power up. By default it is set to reset, which is dumb.
Attached is picture showing the culprit settings in default.
In the picture I have already changed them
Hello, I'm having a hard time understanding how to get a Modicon M340 to pull a Modbus address from an ABB Totalflow via Ethernet. I set up a port...
1,154
Hi, Does anyone know if programming a Modicon M580 is basically the same format as an M340? Also do they use the same software package? Thanks...
1,777
Hi all, im in urgent need of some help in programming a telemec modicon m340. If anybody can help i would greatly appreciate it. Cheers
1,839
i make the program in plc m340 schneider and dump the program into it.but its indicate i/o problem.what is best way checking procedure:D
2,839
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
