Schneider PREMIUM PLC-Not connecting in Programming Mode
shubham_khare
Aug 2015
nagpur
We are having Unity Pro XL v5.0 through which Premium PLC is communicated, when I was trying to connect It is not going directly to programming mode and says the programming mode is not available and can be connected to monitoring mode. If it is connected to monitoring mode, it show the status and after 5 – 10 minutes one message says PLC reservation is just released and can be connected to programming mode. But if trying to connect to programming mode, again the same message comes and only monitoring mode is available.
Tried power recycling, downloaded with backup program, but still the same result. physical communication is normal and in monitoring mode it works and program runs fine, but not in Program mode so unable to edit. I am using CPU ethernet port for communication.
In Unity under tools/options click the connections tree and select default connection mode as as *Use Programming Mode*
EDIT: Also some quantum CPU's have a keyswitch on them to lockout programming mode, im not certain about premium.
is the error message just "programming mode is not available" or is it more like "programming mode is not available reservation is held by <computer name>"?
sounds very much like there is already another computer connected to the plc.
you can only have one connection at a time in programming mode.
if there are no other computers is it possible you opened the same program in unity twice and you are already connected?
Hello Everyone, I have one task which involves migration of Premium PLC CPU P57104M to M340 PLC. My senior have given me converted program from...
3,907
HI, I am working on Schneider Premium PLC P57 454, how to check scan time? Awaiting your answer's to my query.. Thanks
3,109
Hi everyone! What can i do if the PLC has no upload info? Please help me... 🤞🏻🤞🏻🤞🏻
1,843
Dear All, Good Morning. I am trying to connect STB NCO2212 with TSX P571634 PLC via Canopen Communication. But i am unable to configure the...
3,586
Hi all, Just trying not to reinvent the wheel (and save time). Has anyone got any example code or tips for using schneider unity pro to...
1,893
