scp maximum value calculation formula
Qaisar Ch
Apr 2017
lahore
hi guys,
is there any formula to calculate input maximum value in SCP block where input minmum value is -25383 on 0Kg
what will the maximum value on 1, 2 ,3,4 Kg
on 5 kg vaue is -22480
Your difference between the input max and input min is:
-22840 -(-25383) = 2903
So if we want to know the value at 4, calculated as follows:
5/2903 = 4/x
4 * 2903 / 5 = x
2322.4 = x
Now we add this to the base at 0 which is -25383
So the value of 4 will give -25383 + 2322.4 = -23060.6
Regards,
Hello, I am replacing a pH probe that was determined to be bad in a waste water treatment system. I am replacing it with a 2-wire Aqua Metrix...
1,454
Hi I have a PLC 5/40E which passes speeds to a number of machines via rio. Currently there is no scaling and the machines use look up tables...
1,723
Rs logix 500 is version 12.00.00 and my SCP instruction is grayed outed. Can anyone help?
1,306
Hello everyone, I am using SLC 5/03 (1747-L531) CPU. My CPU gives an error. BATT led is active and it is always in solid red . Firstly I...
4,119
Anyone know where I can get a replacement key for this? I know that it said "01115E" or "0I115E" on the side of the key. It was brass. Not much...
998
