Scroll wheel on mouse crashes WinCC Flexible.
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,342
Hi on a collegues PC, when he uses the scroll wheel on his mouse, WinCC Flexible crashes - every time.
It does not happen on my own PC.
I vaguely remember seeing a note or FAQ about such a problem, but I cannot locate it now.
Anyone have any ideas ?
OK guys, dont waste your time with it.
There was a Logitech cordless desktop utility in the systray. After removing it, the problem disappeared without any negative effect on the mouse usage. Only the cursor speed had to be set in Windows control panel in stead of in the systray utility.
Anyway, this confirms one of my mantras:
Remove everything from the systray unless it is really really critically necessary.
One of the few times where Less = better.
I've seen this with Word & Excel. It seems to happen with mismatched Logictech utilities (doesn't match the current mouse ver). As soon as system resources are required it crashes the app. It would only happen when I had very large Word or Excel projects.
Let me guess...serial not USB mouse.
Nick
Hello Thank you all for your support. I am actually experience same issues with TIA portal V17 update5 as well as V18. The problem is with the...
820
Say I take some MODBUS registers and pull into my Logix plc DINT array (sequential). Now, I get a little fancy… using FactoryTalk View SE 13.00...
18
3,235
Hello Friends I have a ML1400 program with 10 message faults aprox. and a PV800 program with a Multistate Indicator showing the faults. When...
1,737
I'm testing an FTView SE application on a Windows 7 machine, and I've got scroll bars appearing for a display, but not initially. The SE Client...
2,460
Hello. I have 130 Inputs in my application, so I would like to create a scroll list with 2 columns. Any ideas? I have FT View ME 7.0 Thanks.
1,643
