Seeking a more reliable reading
RobertB
Oct 2017
WI
78
Hi, all.
I have a ML 1400 ser A, using a 1762-IF4 analog input card.
I am using the -10 to +10v setting on I:1.0
When the analog sensor takes a process measurement, it sometimes reads low. I've entered some extra logic to track and catch 4 measurements in 1 second.
During the measurement, nothing physically changes, but sometimes the 4 readings are slightly different.
Is this just the limitations of the IF4 card? My readings are set to refresh at 130ms.
Any advise would be appreciated.
The bad reading is usually 5%less. The sensor cable is NOT shielded, but there is only 120V nearby....and that is almost 2 feet away from the sensor or the cable.
Is there any way your sensor can be configured to output a 4-20ma signal? Direct voltage readings can be quite sensitive.
Hey, Madison, WI! Tomah, WI here!
I believe there is a way to "damn-up" the electrons by using a resistor to convert a 4-20mA into a 0-10volt signal...... But, I don't know of a way to do it vise-versa.
Before I went through the trouble of trying to convert, I would start with swapping the cable out for a shielded one. How long is the current cable you're using?
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
158
I'd like to display 2 weights at an operator station on the plant floor. These two weights are in our L71 PLC as a DINT but I can easily convert...
1,774
I have a PLC5/80E that I want to poll a Modbus device into using a Digi1. I have setup the message as a multihop going to the IP adress of the...
1,437
As mentioned in the title, I want to learn about PLC systems. Long story short: I had to strip out a plant room. Everything was going to the...
2,609
My attempt to communicate with Foundation Fieldbus transmitters with Pactware and a new, out-of-the-box Softing FF modem are a disaster - failure...
17
5,048
