Seeking Ethernet/IP Display Unit
smithe213
Aug 2017
Nova Scotia
I'd like to display 2 weights at an operator station on the plant floor. These two weights are in our L71 PLC as a DINT but I can easily convert them to a string value. Ideally I would have a small LCD or LED display communicating via Ethernet/IP that I could just push a string to. 2 lines with 14 characters each is all I need:
xxxxL: yyyylbs
xxxxL: yyyylbs
I see several LED "Marquee" signs that support Ethernet/IP online but these appear to be much larger than what I am looking for. Preferably this would be a reasonable size for viewing from a few feet away at most so maybe about the size of a sheet of paper.
Does anyone have a suggested product for this, or should I just be putting a full HMI station in for this?
Thanks,
My inital thought is a small touchscreen display with either AdvancedHMI (free) or VTScada (or similar), but that seems excessive. I see that Automation Direct has LED displays, the MD4-0212T particularly is a 2-line screen that looks to be ~23"x6", but that only has 12 characters per line.
Thanks everyone, I ended up putting in a small Maple Systems HMI screen. It was cheap enough and in stock, we have since ordered more to replace some other displays with long lead times.
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
181
I have a PLC5/80E that I want to poll a Modbus device into using a Digi1. I have setup the message as a multihop going to the IP adress of the...
1,450
As mentioned in the title, I want to learn about PLC systems. Long story short: I had to strip out a plant room. Everything was going to the...
2,632
My attempt to communicate with Foundation Fieldbus transmitters with Pactware and a new, out-of-the-box Softing FF modem are a disaster - failure...
17
5,086
A former customer of mine (I'm retired) in the Somerville New Jersey area needs some help with a machine. It has an Automation Direct DL06, C-More...
1,669
