rsdoran
You can use the cable type and run it 50-100 feet with no problems, and series several for the 300 feet you mentioned. Try to keep them in line of sight i.e. after any turns place on separate system. This method would mean 4-6 actual estops with an indicator light to specify which has been used.
Safety monitoring may be necessary but I believe estops should be maintained for 2 reasons. First, someone needs to look at the area the estop was engaged to determine why, an operator is not the only that may activate an estop; ex: forklift driver sees jamm on conveyor, hits estop gets back on lift and drives off.
Second, an estop should never reset a system; therefore the person that will be starting the system should know when it is appropriate to do so i.e. should know where it was estopped and why, verify manual reset then restart system.
Just my thoughts.
I think Steve was thinking the same way I would, using spring return type Stops can allow the system to either start on its own or allow an operator to restart without determining why it was stopped.
Just my thoughts.
