Seeking job in Industrial Automation/ PLC. Questions regarding skills and requirement
nerdbotbot
Aug 2017
Bangalore
1. Breaking into the Industry: Most of the jobs require at least 2 years of experience and familiarity with certain PLC hardware and software. However, cannot find any openings for freshers.
2. PLC Languages: I'm familiar with Ladder and Function Block Diagram. Recently, started working with Sequential Flow Chart. Will these three languages cover major applications? Should I also learn Structured Text, Instruction List, and Continuous Flow Chart?
3. PLC Applications: I have only worked with fluid power (hydraulic and pneumatic) drives. Typical I/Os were: solenoids, digital sensors (reed, inductive proximity, and pressure switch), Potentiometer (±10 V), linear analog sensors (0 - 10 V). Which are the other systems (electrical drives) and I/Os used with PLCs ?
4. Prerequisites for SCADA: After learning the basics of Ladder Logic and FBD, I evaluated PLC software from different vendors. The only difference was User Interface, programming logic remained the same. Similarly, every PLC vendor has their own SCADA software. Are their any basic prerequisites, like, C, Visual Basic, SQL, JAVA, etc. that would be helpful?
Thank you
The first thing you need to do is learn how to do internet and forum searches. This has been discussed many times here and elswhere on the internet, like Linkedin.
The Second thing you need to do learn how to take criticism without getting upset.
Why?
Because every time anything goes wrong on the machine or system you worked on the program/programmer gets the blame first.
Why?
Ah yes,
- It's the program
- It's electrical
- It's not mechanical it's operator
- Fine, it might be mechanical
Yep, the program couldn't tell which size fuse the maintenance guys were installing, and after blowing a box of them, we need to get the programmer in here! HaHa!!!
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
154
I'd like to display 2 weights at an operator station on the plant floor. These two weights are in our L71 PLC as a DINT but I can easily convert...
1,773
I have a PLC5/80E that I want to poll a Modbus device into using a Digi1. I have setup the message as a multihop going to the IP adress of the...
1,437
As mentioned in the title, I want to learn about PLC systems. Long story short: I had to strip out a plant room. Everything was going to the...
2,609
My attempt to communicate with Foundation Fieldbus transmitters with Pactware and a new, out-of-the-box Softing FF modem are a disaster - failure...
17
5,037
