Sending data out of a ML1200
Kyle Grathwol
Dec 2005
Sandusky, Ohio
129
I have several ML1200's with 2 serial ports. Is it possible to send data out the serial port to a PC that is attached and dump it into an Excel spreadsheet? If so can you recommend a bulletin or publication that explains how to do this?
Thanks in advance for your help.
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
67
Hi Everyone, We have Silo System which has temperature sensor and these sensor data will be communicating through RTU unit to the Dedicated PC...
624
Hello, Thanks in advance. How can I send more than 82 characters using AWA or AWT? to Zepra Printer via serial Rs232 communication? Normally I...
777
Hi all I have a project on the go and would like to send data from a Siemens 1500 to a Siemens 1200 What is the best function to use ,would it be...
4,493
Hi all, I've only worked on Profinet once before to talk between a few S7-300 PLCs. I managed to get the system communicating by using the "GET"...
2,585
