Sending Signals from Control Logix to SLC 5/05
Musbtr1pin
Jun 2014
Cedar Rapids
I need to send a signal from a Compact Logix to a SLC 5/05.
This ultimately will be a run signal that I will get from upstream communications, and the SLC will receive that signal allowing my machine to run.
What is the easiest way to go about this?
Same subnet mask..
Where the SLC5/05 is the machine controller that is looking for a permissive I would actually have the SLC5/05 do a MSG read, where the SLC reads from the CompactLogix rather than have the CompactLogix do a write message. The read message overhead is lower.
If you have a techconnect contract for keeping your Logix software current then reference technote 32228 in the AB KB for an example of how to do this. If you don't then get back and we can walk you through it.
I have an AD D0-06DR and I'm trying to communicate with an Electroin Displays brand LED message board. I'm fairly new to the PLC game and this is...
2,003
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
134
111
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
441
I've been having some trouble figuring out how to get the ip address for the mail relay server, is it something that I need to create separately...
962
