sending UDP messages
DJShardy
May 2018
Melbourne
Hi, I have a Micro 1400 that I have a project for. I am trying to make it send and receive data via UDP.
I have followed the Rockwell guide but I am stuck at the point of how to enter the IP address & other Data.
I have attached link to a folder with screen shots, the project & also the manual.
Chapter 24 has all the info.
Any pointers on how to-do this?
https://1drv.ms/f/s!AuKnXmIB4gtttSJyHAnxGbAz790b
Are you unsure of how to enter / convert the IP address to byte?
Use the Windows calculator in Programmer mode. On the left, select DEC. Type in the first octet of the IP address. (example - 192) then switch to Hex view. This should give you C0. So, for an IP address of 192.168.1.253, your four bytes for the N file would be C0 A8 01 FD.
Hope this helps.
Hey guys. This is my first time delving into UDP commands, at least from a PLC standpoint. My setup is as follows; Productivity 2000 PLC...
17
6,381
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
90
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
422
I've been having some trouble figuring out how to get the ip address for the mail relay server, is it something that I need to create separately...
914
Hi Everyone, We have Silo System which has temperature sensor and these sensor data will be communicating through RTU unit to the Dedicated PC...
616
