Sensor for measuring % of ethanol in water
bundhit
Sep 2003
Bangkok
39
I try to find sensor for measuring ethanol in water in search engines.
But there are little topics involve. Does anyone know which sensor
can measure percent of ethanol in water and
its transmitter send the output signal in 4-20 mA format please suggest.
I'm not sure if such a device exists.
To find a way around:
My best bet would be to check with a supplier of ethanol. Not to buy some but to get a list with specifics for ethanol.
For instance the conductivity, dencity, and so on.
Basic idea, find something destinctive that makes ethanol different then the stuff that it is mixed with.
When you have this info go to a suplier of measuring devices and hand them over the specs. Endress & Hauser have a large range of differnt measuring devices. See what they come up with.
Jurgen
Following up on jurgen's suggestion, I did a google search using "specific gravity sensor". That resulted in 43 hits.
If ethanol and water are the only substances in the mix, your task is vastly simpler than if there could be other substances.
Hi Everyone, Working on my first job that will have some motion functions. The process involves pipe running on a conveyor system. The conveyor...
2,624
Hello All! I know this may not be quite an appropriate question for this site, but.... I am looking fo a non-contact sensor to measure the...
3,928
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
113
Hi, Need help with coding for a faulty component sensor which we are using a push button as we are using a test rig. the plc is a allen bradley...
213
