Sensor for measuring web thickness?
PLCRookie
Dec 2005
I'm right here...
305
Hello All! I know this may not be quite an appropriate question for this site, but.... I am looking fo a non-contact sensor to measure the thickness of a Web as it is fed into a machine. The material is a filter type media composed of basically paper fiber. The problem I am trying to solve is that the supplier of the paper is prone to "splice " the roll during production, and this causes us tremendous problems when we try to process it . The splice is almost always overlapped and then taped. This causes my process to jam severly, resulting in about 20 minutes of downtime on each occurance. If I can detect the splice, and stop the machine, restarting takes about 1 minute. Until QC can resolve the problem with the vendor, I want to install some sensors to detect the thickness difference. The range is about 1mm for a correct piece, anything more than 1.5mm should be detectable. Anyone with first hand experience with this kind of sensor?
I have looked at most of the sensor sites that I usually use, and none struck me as a good match.
đź“š
All comments greatly appreciated!!!!
A relatively inexpensive option might be to use something like a Keyance laser, looking at the web going over a constant angle idler roll (load cell roll would be ideal if properly designed)...
Either use the analog output to tell of a large delta, or get one that can be programmed to give a go/no-go digital output.
I only suggest Keyance as a brand name, as I know they can do this, but others (Banner, uhhh... well, others) probably can as well.
Costs should be in the $1500 to $2500 range.
---- EDIT ----
If you are dealing with material from a supplier, and are on good terms with them, then perhaps an even cheaper solution would be for them to use a specific color for their splice-tapes. In that case, a color sensor would be cheaper, and give a nice on/off output.
Banner would work for that (again, as others).
Along the lines of detecting the spice tape, I had excellent luck using a Sick KT 3W-P1116 contrast sensor (US$170.00 list) to detect splices in foil-backed cap lining material.
-Eric
The question is appropriate for this forum, especially if we learn something in the process!
I started the Google search with 'paper thickness detector'. I suspected ultrasonic was the way to go. This link shows what should happen when 2 webbed sheets are overlapped:
http://www.bbhscanners.com/products/spectrum_xf/UMD.html
Next, I searched for 'ultrasonic thickness sensor'.
The line from Sick looks like a perfect match. Your application is mentioned on page 2:
http://www.sick.com/us/products/new...le.tmp/Ultrasonic Sensors Family Overview.pdf
We use several means of detecting splices, banner makes a photocell (for lack of better words) that will see different colors that we are going to implementing here, if you can have your supplier change there tape to a different color then your product, we also use a lot of SICK products they are good but they are going to cost $$$
I assume you are running at high speeds. With a splice detector, sensing the splice with a sensor is one thing. You can't forget about the device to read the high speed signal. I used a sick sensor and a siemens logo plc(programmable relay) on a splice detector a few months ago. Are top speed is 750 FPM.
PLCRookie,
I just had a demo on a camera system made by Banner check here, this is one of their models, $1,300.00 I think it may work for you as well, we are getting 2of check back with me in a month or so, if you are still looking for one and I will give you the review
Thanks Genius. I think Im going to use a ultra sonic for this app.. but we just got a small machine built locally with this Banner unit, and it looks like we will get more in the future. Thanks ALL!
Hi Everyone, Working on my first job that will have some motion functions. The process involves pipe running on a conveyor system. The conveyor...
2,614
I try to find sensor for measuring ethanol in water in search engines. But there are little topics involve. Does anyone know which sensor can...
5,099
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
113
Hi, Need help with coding for a faulty component sensor which we are using a push button as we are using a test rig. the plc is a allen bradley...
212
