Sequential Status Display...
icky812 said:
For those that need a bit more than what the Directsoft manual provides on how things work, here is a document that I wrote...
Thanks, Icky -- your timing couldn't be better! I've had my head buried in manuals for the past few days, and even though the DL manuals are well-written, sometimes they can be very dry.
And it can be very difficult to filter out the less important points from the more critical info. I printed out your write-up straight away, and it's already been very helpful!
Paula
And also thanks for the translated logic, Icky! I'll investigate it further when I find some time. At first glance, I'm not liking the 'dreaded' stages, but I'm sure I'll figure out a way around needing them... :D
In any case, it should be useful for Bob (testsubject)... ;)
beerchug
-Eric
Paula,
I'm just glad to know that someone somewhere got something usefull out of it. :)
Eric,
No real need for the stages. A contact in front of the rungs inside stage S1 will do the same thing. I tried to use a few not so well known 'features' while doing this just to show how they work.
Sorry to dig up this old thread.
But i am trying to do near enough exactly the same thing using microwin s7200 ,im not proficient with programming and cant work it out can anybody offer any pointers.
Just trying to display multiple messages to an led display screen scrolling through each message , controlled by sending individual output bytes for each message.
Hi there, We have a system at a water treatment plant where large raw water tanks feed into the plant that's all on the same level. At high tank...
18
3,773
Hi, I started off my career in PLC programming doing water/wastewater on AB around 20 years ago, but then moved overseas a few years later and...
57
12,098
It appears to me that Logix is improperly executing sheets of an AOI in sequential scans instead of the same scan as the main program. To test...
1,681
Hi, is it possible to read the name of the steps in an S7 Graph sequencer? In the parameterinterface there is, for example the parameter #S_NO...
21
7,207
Hi All, is there a way to incorporate SFC with HMI in some way, in order to represent missing conditions for next step. Something similiar...
980
