Serial RS422/RS232 on PLC to Display
PowderMonkey
Sep 2015
Antibes
Hi
I wanted to control 4 Displays to switch input from a PLC with serial interface.
The Display can be controlled via its serial port with ASCII command.
How can I achieve that?
Thank you
If RS-232 you will want one port on the PLC for each HMI. If RS-485 and all of the HMI units use the same protocol you will need to verify that the protocol selected supports multi-drop and that the PLC supports multidrop on this protocol.
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,054
Hi, I am trying to read weight from a Mettler Toledo weigh scale (ID1 Plus-A) to S7 400 seriec PLC, via CP441 serial card and RS422 interface...
1,826
Hi everyone, In my coming project we have to convert Serial RS422 RK512/3964(R)protocol to Profibus DP Slave(Baud Rate 1.5 Mbps).Any one who...
2,424
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
181
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
152
