Serial to Ethernet conversion...
userxyz
May 2002
any
2,768
Is there a modul that can convert Serial 9 pins to ethernet ?
We now have telephony central that can print on a V24 Serial port, but the printer is located 140 meters further. So we have a conversion to telephone line, at the location of the printer we reconvert from telephoneline to printer...
But, is there something that can convert serial V24 to ethernet and the hook up a printer on the ethernet...
DLink make a USB to Ethernet converter - I have one. Not sure about serial though - serial is vanishing in the PC world and there is not much call for it now.
DeviceMaster RTS
C O M T R O L makes serial device servers in a variety of port density options from 1 to 32 serial ports across a single Ethernet connection.
Hi Combo
I haven't read the data for the EtherPath® SS-1R that closely and so may well be wrong. The Serial Ethernet modems I have used don't let the serial device put data onto the ethernet cable independently there always has to be a computer at the far end that is in charge of the comunication. So I don't think you could use this to go from serial to ethernet and then hook up your printer on to the ethernet. What it lets you do is have a serial port at a remote point via ethernet and the software creates a virtual serial port on the computer.
You should be able to do what you want with a small embedded computer like this one from Moxa. Though you will have some configuring and maybe programming to do.
Bryan
only 150m...why telephone? granted it will get round the globe (or even outside of it) but i would consider an RS-232/RS-485 adapter set and this can do about 1.5km and is simpler/cheaper.
i have used rocketport from ******* to do just what you're asking though - works very well but i use this when I have a LAN/WAN and you have serial devices (eg modem) you want to communicate with and utilise the existing ethernet architecture.
Is it possible converting Omron and Keyence plc's serial communication into Ethernet using serial to RJ45 converter? I need to connect these plcs...
2,278
Hi, I have been using the Anybus gateway AB7007 so far for integrating a serial device with Ethernet I/P gateway. But now I would like to use the...
1,904
Hello, I have a setup with 6 devices on ethernet and 1 device on RS232. I have chosen for a 315 PN/DP CPU. For the ethernet devices, that...
4,595
I would link info on cheap solution to connect to slc504 via wireless for program monitor and modify. no i/o data use Tony
2,831
Hi All, Looking to get some direction on how to get data from a piece of equipment that has RS-232 communication (1-way) to a 1756-L73...
349
