LTSpice. It's free and great for checking circuits like this.
http://www.linear.com/designtools/software/#LTspice
http://ltspice.linear-tech.com/software/LTspiceIV.exe
I didn't want to post the answer and hurt feelings
whose ??
I jest. Jokes aside, even LTSpice as a scaled down program allows you to do some pretty good diagnostics. The scoping and transient analysis was always pretty good. I've forgotten how to use it, but the Tranfer Function stuff was helpful at times as well.
Here it is....
I don't know how to annotate it but V(n001) is point B in the circuit
How do you get the operating points window to pop up like in your image?
You need to "Run" the simulation. The first time you run it; it will prompt you for the simulation type. For this exercise you can pick "DC op pnt" from the Edit Simulation Command prompt.
Also, it will tell you all the node and point names when you mouse-over them.
Google and YT get hits on LTSpice tutorial, and there are many example circuits varying from basic to advanced.
First time I've even seen it, but it looks useful. I downloaded and installed it and managed to build that network, in a couple of minutes, and ran the simulation. I was happy to see it agreed with my manual calculations.
I don't think it would help with digital circuits, such as my 8x8x8 RGB LED Cube project, as that is all multiplexed, but for analog circuits it could be a great tool.
