Server 2008 - Windows XP Time Sync...
Paullys50
Jan 2006
WI
2,188
Here is my setup, I have a SCADA Server running Windows Server 2008 which running my Wonderware InTouch DAS server. I have multiple Windows XP clients (InTouch application setup for NAD) referencing this IO server for tag data. I am looking to synchronize the time between the Server and Clients so when I look at data trends, everything is in sync. Server would be the master time keeper and the clients would be children referencing the server.
I have not configured a time sync like this, it seems like it should be easy but this system is "Live" so if it requires and server reboots to implement, I need to plan accordingly.
Currently at site, will do a better job of searching the forum later today to see if this has been covered else ware.
Thanks!
Do the XP client computers authenticate against the Windows 2008 Server as a Domain Controller ?
If so, the time gets automatically synchronized.
If not, it takes a lot more work to configure the Server as an NTP server, make sure it can get an accurate time (like from the NIST servers over the Internet), and configure the XP computers to use the Server 2008 computer as their time source.
I had to do this a couple of years ago with a Windows 2003 Server as the time source, and XP SP2 as the clients. It was quite a pain; virtually all the reference information you can find refers back to the default Domain method that makes everything automatic. There were registry changes and reboots and patches for the XP boxes (to catch up with the DST changes).
Ken -
Sorry about that important detail domain/work group...it's the later just a work group.
I found some info on setting this up manually, but it was referencing registry tweaks/changes which has gotten me nervous. It is not critical, just an annoyance.
Check this out:
http://blogs.msdn.com/b/w32time/archive/2009/08/07/net-time-and-w32time.aspx
not sure if its exactly what you are looking for, but my integrator put this on a small workgroup of winXP (only) machines and it seems to work ok- they put the NET TIME command into a batch file, and task schedulered it to run every night at 1am (or so). You might need to (re?)-learn from batch file programming, but it syncs the time and is very 'slim'.
-John
Check this out:
-John
John -
That looks like it would handle what I am looking to do! I'll be looking deeper into this solution. Thanks again!
Hi guys. We use a desktop computer running a application via factorytalk to allow operators to interface instead of a HMI. The hdd is...
1,895
Does anybody know when Rockwell will start supporting Windows server 2008? I ordered a new server and I asked for Server 2003 amd our IT...
2,913
October 22 2009 is the official date for both o/s releases. I am using Win 7 as the primary o/s on my home PC and using a vm on my laptop with...
19
13,089
Hi all, I'm trying to open a project with Factory Talk view studio V8.1 but am getting the error: "FactoryTalk View cannot authenticate with the...
3,009
Hello, I just installed FTV V8. During installation i gave password for my SQL server. But finally after installation im not finding SQL Server...
3,572
