Servo Amplifier MR-J4 NOISE in power line
zai_jnr
May 2008
MALAYSIA
169
Hi there,
Currently I'm working with PLC Mitsubishi Q series and Servo Motor MR-J4 series.
All the system will monitoring using one PC that installed SoftGOT2000 inside PC for operation.
Currently I'm face NOISE in power line when I start SERVO ON signal to my servo system. What happen is my monitor PC will start show vibration/noise on it display.
From servo amplifier to servo motor, the distance power cable is around 50mtr, and same goes to encoder cable 50mtr..
To run the motor is no issue when I'm start to run ( but monitor PC still show the noise on it display).
The NOISE will only appear in system when SERVO ON signal is turn ON...
Power cable I'm using shield cable spec.
Any suggestion to eliminate NOISE in power line servo motor?
Some Servos come with a Ferrite Choke which you wrap a few turns of the lead. Depending the Frequency of which the noise is at. It is probably the simplest solution. Also making sure you are Using the best Heaviest shielded cable and not run the Encoder close to the motor leads.. Most reputable servos have already done everything to curtail common mode currents. Making sure grounding is Correct and avoid Grounding loops.
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
70
We have a system using a Omron G5 Servo. The motor has failed and Omron has advised the delivery time 4 months for a new motor! I'm not overly...
1,636
Hi guys, Any one know about this PLC, please let me know. I am interested in how to reset the dynamic breaking of Mitsubishi Servo motor. Best...
1,393
What is error n12, n13, and 1A.1 on a MR-J4W2-44B? I can't find these in my Mitsubishi troubleshooting manuals.
1,595
Hello everyone, I am new to servo motor.. And i am using fuji servo with s7 1200 Now the problemb is i am not able to connect my pc to servo drive...
1,583
