Servo drive ac servo motor fault
RBergmann
Jun 2002
California
258
Have an Elwood SX servo motor and a IndraDrive (Bosch) amplifier controlled by IndraControl MLC (i.e. PLC). Upon connection, message referencing a fault code C0220 (encoder). Have multiple (5) axis' and swapped drive motors, drives and cables. Cannot see consistencies for the fault. Have confired with Elwood and Bosch with no joy. Anyone have ideas?
...rab
Ive put Elwood motors on Siemens Sinamics S120 drives. I had to do an encoder alignment procedure with the S120's
Maybe this needs to be done with your Bosch?
Could you briefly explain this procedure? We've obtained software for the Sick encoder in the Elwood motors to delete the encoder field. Supposedly (before I was involved), Bosch provided us with a configuration file that should have automatically reinstalled the correct configuration to co-ordinate the Elwood encoder with the IndraDrive.
... rab
Hi guys, I need help with position control using a Veichi AC Servo Drive model SD600A1-T2-2R2. How do I know how many pulses for it to rotary 1...
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
112
I am looking for some suggestions on good Ethernet/IP servo drives to communicate with an AB PLC. My customer has a non motion PLC but wants to...
1,195
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
900
