Servo Motor and drive
Short answer: yes
However, in my experience, servodrive and servomotor manufacturers typically have their own cable sets that are made to match up to that manufacturers drives or motors. Plus you need to be extra careful to ensure that a particular drive/motor matches another manufacturers motor/drive.
That is, it is much easier to commission a system if both servomotor and servodrive are from the same manufacturer but it can be done.
Yes but...
First the motor feedback, commutation and electrical levels must be compatible with the drive. Depending on the drive connections you might need to make a custom cable which can be tricky to do with the right shielding.
Then you must put the proper parameters in the drive for the motor.
Tuning the system could be tricker because many drive manufacturers include pretty good default tuning for their motors but with a different mfg motor, you will be on your own.
Last, and maybe most important depending on your level of skill, as AustralIan said, you will likely not get much support from either the drive manufacturer or the motor manufacturer as they will just point to the product that is not theirs and blame it.
Hi there, I want to purchase a servo motor for Kinetix 350 (2097-V31PR2-LM) but am a little bit confused. Though in AB website, it says the...
1,435
Dear All, I have a machine of stone cutting CNC. with Siemens 810D system. I am very tired to maintain(Servo drive failure) it now wants to...
4,905
Hi, I am facing a problem in my cut to length line servo system, problem is such that whenever i am running more then 1.5 mm thickness material...
2,515
I kept getting Kinetix 6000 servo drive fault of E04 (motor overtemp fault). The servo motor is MPL-B450F. The motor was barely warm, certainly...
9,589
We are still not yet fully decided on the brand of motors and drives that we want to go with and standardize to. We are now looking at Rexroth...
20
10,779
