Servomotor position precision
Kataeb
Jan 2007
www.livelovelebanon.com
636
Dear Sirs,
Does anyone have an idea about the servomotor position precision in degrees ?
We have the following hardware on our machine:
Servomotor 3000rpm,0.82kw,2.6Nm,3.01kgcm2,+resolver, Siemens 1FK7 042-5AF71-1TA2
Inverter 1.5kw, 4A, motion control, +SBR2+CBP2+SLB Siemens 6SE7014–0TP50+ZC33+G91+G42
What is the minimum angle detectable by the SBR2 card ? what is the precision of the angular position ?
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
243
hi goodday to all, i have acopos 1320 as below title my acopos not driven a servo motor,. please help me,.
454
Can we open a servomotor body, then reassemble it again without issues ? Because the customs at the airport want to see the inside of the motor ...
876
Do you know a supplier for the following item? Similar parts and other brands are acceptable. cooling fan for servomotor mounting Rexroth...
1,374
Kindly, we are using ip65 servomotors on diaper and tissue machines. But we are considering the ip64 servomotors for new projects. Has anyone...
1,019
